clucth problems
clucth problems
when I was driving home the other day It got really hard to put into gear and if I came to a stop and tried to put it into gear the car would start moving forward and I would have to turn the car off to get it in to gear. so when I got home I decided it was the master cylinder. After I changed the master it had the same problem, so I decided to change the slave. after that it had the same problem but after messing around with it for a while it worked fine. the only problem was that every now then it would stop working so I would take the resavor cap off and it would work fine. but recently the problem came back and nothing I do fixes it. Do I need to bleed it more? is it the throw out bering? should I get a new clutch? any help is appreciated.
Btw it does not have a bleeder screw we just pulled the slave off and pushed it in really far and it pushed out a bunch of air bubbles out the resivoir and thats when it started working but now it doesn't work no matter what we do.
Magenta_Hearts
Mar 25, 2015 10:24 AM
