Changed my gears to 3.73 what should the RPMs be?
Old Oct 13, 2005 | 08:28 PM
cdn1994z28's Avatar
I have 1994 Z28 with LT1 and the A4 automatic, what kind of RPMs should I be seeing @75MPH with 3.73 gears? I'm now seeing 3000RPM . The car seems to be screaming now, like it used to @90+MPH.
Old Oct 13, 2005 | 09:16 PM
cpt_bimes's Avatar
Re: Changed my gears to 3.73 what should the RPMs be?
^that sound like a 4.10 rpm man..
Old Oct 13, 2005 | 09:51 PM
My handy calculator shows, in O/D with a stock tire diameter, at 75mph:
3.73 - 2,550rpm
4.10 - 2,800rpm
Old Oct 13, 2005 | 10:08 PM
cdn1994z28's Avatar
what would the RPMs be if the tranny was still in 3rd gear @75MPH and not in OD? Would that explain the High RPM's? last shif point seems to be about 50MPH
Old Oct 13, 2005 | 10:10 PM
ws6transam's Avatar
3.73 - 2,550rpm
4.10 - 2,800rpm
That sounds right. My 700R4 equipped Trans Am had factory 3.73's and I put 138,000 miles on them like that. 70 MPH was indeed a hair under 2600 RPM.
The 700R4 has the same gear ratio as the 4L60E.
If you are seeing 3000 RPM, then you are probably not locking up the torque converter or getting it into overdrive.
Old Oct 13, 2005 | 10:27 PM
cdn1994z28's Avatar
Ok so I used the Tuner Cat program today to fix the speedometer, which it did, changed the fuel cutoff speed up as well, but now the engine is revving a lot higher. Didn't knowingly change anything else, is there something that I should change that would fix the OD not kicking in? This is turning into an adventure.
Old Oct 13, 2005 | 10:42 PM
Bow94z's Avatar
Do u take notice to see if it shifted into overdrive?
Old Oct 13, 2005 | 10:53 PM
cdn1994z28's Avatar
I think it did, but really screamed when I stood on it, almost like it went into 2nd @ 70MPH! The shifts weren't exactly crisp or hard, it was wet out when I was test driving it today so Iwasn't able to really push it. Just doesn't seem right. Really wondering if I screwed something up when I fixed the speedo.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
mattszm6
Dec 14, 2014 07:09 AM
