Centerforce Clutch?
Old Jan 10, 2007 | 06:27 AM
94_camm's Avatar
Centerforce Clutch?
Whats your opinion on the Centerforce clutch?it says 90% more hold compacity over stock so how much hp is that?Its ethier this clutch or the ram power grip hd let me know what you think
Old Jan 10, 2007 | 06:53 AM
95LT1conv's Avatar
stay away from centerforce IMO. have you considered a Mcleod single disc? runs about $450 for PP, disc and T/O bearing.
Old Jan 10, 2007 | 02:38 PM
Bayer-Z28's Avatar
I paid about $950 for my McLeod single w/ PP, FD, FW and Master Clynder. (from Speed inc.) You should get a Flywheel that is matched to the clutch. Or have your resurfaced and ballanced to match the clutch you buy.
I've heard that the Centerforce clutches have disengaugment issues. The centrifugal weights get 'stuck', and make it difficult to release the clutch. -May also be due to not addressing the master clyinder also, not enough throw.
I have the McLeod single clutch and I love it! It's been in for over 3k miles, w/ some beating on it. I needed the McLeod Master to get it to disengauge fully after the install. It has a nice stock feel to it, besides the heavy pedal. It engauges smooth w/ minimum chatter. It's the Kevlar/Organic disk. If you get a dual Kevlar disk, it will have some more bite to it and possibly a little more chatter.
Old Jan 10, 2007 | 06:06 PM
94_camm's Avatar
ok i bought thiss off of texas-speed.com
-McLeod Performance Clutch Disk, 1993-97 LT1 F-Body
31-261871
-McLeod Pressure Plate with Throw-Out Bearing, 1993-97 LT1 F-Body
More Detail 31-360822
Sound good?
Old Jan 10, 2007 | 06:48 PM
95LT1conv's Avatar
that will be a good combo. just remember to have your flywheel resurfaced
Old Jan 10, 2007 | 06:50 PM
95LT1conv's Avatar
i didnt have any issues at all with my install. still using stockmaster and slave. no chatter at all and the pedal pressure didnt increase at all. no balnce issues either
Old Jan 10, 2007 | 07:01 PM
94_camm's Avatar
Where can i get the mcleod adjustable master cylinder? Do i still need to get the pilot bearing and the alignment tool?i have a brand new stock flywheel is that good?iam getting the flywheel balanced the same weight as my other one for my 383
Old Jan 10, 2007 | 08:03 PM
OBE1 95Z28's Avatar
You won't need the adjustable master cylinder; this is required for the McLeod Twin disk setup.
Old Jan 10, 2007 | 10:39 PM
Bayer-Z28's Avatar
Not every clutch treats everyone the same. I was going to get the Centerforce, but I heard something about disengagment issues... Good clutch tho? How's it holding up?
Not sure about the LT1's, but mine would not disengage at ALL untill I installed the McLeod Master.
Old Jan 11, 2007 | 11:25 AM
95LT1conv's Avatar
[QUOTE=Bayer-Z28;4335173]Not every clutch treats everyone the same. I was going to get the Centerforce, but I heard something about disengagment issues... Good clutch tho? How's it holding up?
i was talking about the Mcleod. car had a centerforce DF when i bought it, but that didnt last long
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
