Can a sturdy 10 bolt be built?
Old May 16, 2004 | 09:03 PM
wicked_95z's Avatar
Looking to try to build my 10 bolt to handle about 600hp w/ n2o. Was thinking some moser axles, power trax system, weld the axle tubes on, etc. Is it even possible?
Old May 16, 2004 | 09:57 PM
Josh'95Z28conv's Avatar
The problem tends to be in the ring and pinion gears, not the rest of the rear. I dont think anything else will help it last longer...
Old May 17, 2004 | 12:03 AM
funina91ss's Avatar
I had pretty good luck with mine will all stock parts and a solid pinion support & TA girdle. But I am only putting out 450 RWHP. Best 60ft was a 1.53 with a 3.23 gear.
Now I have the rear apart the posi unit started popping going around turns. Pulled off the cover and found some metal teeth broke off. Very minor ships but still broken parts. It wasn't going to get any better.
But I do have an A4 so don't think any of this will help you out.
79RS
Mar 24, 2015 09:30 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
ChrisFrez
Mar 1, 2015 01:33 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
