built 4l60e or th400
Old Mar 30, 2004 | 01:08 AM
stroked383ta's Avatar
my tranny went out and i dont know whether to go with a built 4l60e or a built th400. if i went with a th400, how would highway driving be like with my gears since it will be a daily driver? what about the costs? which would be less? what parts would i need for the th400 swap? who makes the best th400 or 4l60e? any info would be appreciated.
Old Mar 30, 2004 | 07:39 AM
rskrause's Avatar
Moderator
Lots of questions!
How would it be on the highway? It's kind of subjective, what's ok for one person is intolerable for another. A lot depends on your exhaust system. If it's quiet, the highway rpm's will seem a lot more tolerable with a TH400 than if it's a noisy system. Fuel mileage will suffer (a lot) if that matters to you. FWIW, when I was young (sixties) very few cars had OD. I drove a Dodge Charger R/T with a 440 wedge and 3.73 gears all around the Eastern US for years.
Cost? Depends on what you get. No matter how much you spend on a 4L60 there is no way to make it as strong as a good TH400. IOW, you can't get a "bullet proof" 4L60 at any price.
You don't say much about your setup. The real question is: do you need a TH400 to handle the power you are making? Just to pick a number, if you are in the ~450rwhp range I'd call that a practical limit for a 4L60. You car will be slower with a TH400.
The swap from a A4 to a TH400 is pretty simple.
Carl Rossler builds excellent auto trannies.
Rich Krause
Old Mar 30, 2004 | 09:20 AM
rskrause's Avatar
Moderator
Re: Re: built 4l60e or th400
Originally posted by robvas
Do you really need a 400, or could you get away with a TH350?
450hp, many guys run a TH350.
Have you looked in to the Gear Vendors setup for overdrive/underdrive? Expensive but it might be for you. Built 4L60's aren't cheap either.
http://www.gearvendors.com/
I would never bother with a TH350. You lose the OD and it's not as strong as a TH400. Only advantage: about 15-20# lighter and a little less parasitic loss (couple of hp) than a 400.
Just IMHO.
Rch
Old Mar 30, 2004 | 10:07 AM
look at my sig for setup. i raced my buddy with almost the same setup as mine and i beat him. he dynoes at 435rwhp and 476 ft lbs torque. he's doing 11.8@11X. that might give you an idea.
Old Mar 31, 2004 | 08:43 PM
if i go with the th400, how much slower would it be? what parts are associated with the swap? i might be spraying a 150 shot at most but i dont know yet.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
