Building my 10-bolt up, whatcha think?
Re: Building my 10-bolt up, whatcha think?
Originally Posted by SS RRR
If you've had such success with a 10-bolt that wasn't, "built as it is now.." then what's the point of throwing money at this one? You can buy used 10-bolts for cheap these days.
So you feather the clutch on Streets... Nice... I dump my clutch at 6000+. I reckon that makes me a retard. LOL
Honestly IMO I think you are wasting money if your motive is to eventually get 12-bolt or 9".
I have one solution for you regarding the amount of money you are spending for your wedding.... elope. Congratulations.
Originally Posted by Cmr0z28
Look man, you're talking about being constructive, so let's keep this mature. There's no need to imply that I'm "dense" or "simple-minded". You need to chill out and learn how to accept other people's points of view...
I look at it this way.
-You don't go to the track that often
-When you do go, you launch conservatively
-You're running low on cash temporarily
-You're getting a 12-bolt in the future
So MY point is, why bother upgrading/trying to make the 10-bolt stronger when you probably won't even break it in the first place?? Get it?
Oh, and another thing, no matter what you do, you can't really beef up the 10-bolt. The main weakness is the size (7 5/8" ring gear), so no matter what kind of axles, posi unit, gears, etc you put in, it's still going to be weak.
And launching hard makes people retarded? ****, I never knew that! I guess when I flash the stall off the line, I'm automatically considered a retard.
Retarded for the fact that I simply don't care if my 10-bolt breaks, because I see it as an opportunity to UPGRADE TO A 12-BOLT.
NOW, back to topic, does anyone have any ideas how I can further "beef up" my 10-bolt? I don't care if anyone here thinks it's a stupid or pointless idea, I'm looking for constructive responses to improving my 10-bolt's strength. The stronger I can make it, the longer the rear will last. If the rear is in good condition when I finally upgrade to a 12-bolt, then I will have an easier time recouping some of my money invested by selling off the 10-bolt...
Originally Posted by speed_demon24
My friend is on his 13th 10 bolt, so building it up=waste of money.
IMO there's nothing wrong with beefing the 10-bolt up if it doesn't see a lot of abuse.
BUT, you did say that you are planning to get and install a 12-bolt. How long that will be, should be the deciding factor in your decision to beef up the 10-bolt. If you're only talking about a couple of months, I wouldn't bother. If you're talking about a year or more, then go for it.
If nothing else, it's a little extra peace of mind knowing that you've done what you could to make what you have stronger.
Anyone else with other suggestions? The only things left that I can think of are axle tube braces and welding the housing ends all the way around the axle tubes...
Didn't realize from your 1st post that you already had most of the parts laying around and just needed the axles. I've broken my 10-bolt 3 times before I put in the DTS 12-bolt last summer. 1st time was the OEM LSD burnt up so I put in an Eaton (very happy with it) LSD and 3.73 gears with support cover, etc. Lasted a year before the ring gear lost 3.5 teeth on a 1-2 shift (A4 - tires chirped but not WOT). Had a drivetrain shop replace gears and bearings with solid spacer this time and a year later the pinion gear let go. On a 1-2 shift. The TransGo kit hits 2nd harder than any other car I've been in and it has taken it's toll on the 10-bolt. Of course, the set-ups may be a factor. When I pulled the bearing caps, the shims and carrier about fell on my head -- no pre-load what so ever
In your situation I would've thrown the new parts in it, too. If the parts weren't laying around, I would've just replaced the axles (or was the carrier chewed up, too?) and saved the rest for the 12-bolt. I kick myself in the butt for not just parking the car for the couple of months to save up for the 12-bolt the 1st time.
Congrats on the marriage thing, and best of luck with it.
Yeesh...
If you drive conservatively then the "logical" thing to do is to buy another 10-bolt and take care of it instead of letting it run out of oil.
Zexel Torsens are great for street duty only as long as you don't have an agressive clutch. If your motive was to "beef up" that rearend then you've taken a step back.
Axles are not the weak point in the 10-bolt.
You asked, "watcha think?" and there are those who gave you opinions. You did not like them and started in on the whining about your wedding and your finances and blah blah blah blah.... I gave you a "whatcha think" response since I've had a Zexel and an Auburn and an Auburn Pro and an Eaton and an Eaton 800# HD... so on and so forth...
It's your money, but IMO you are throwing it away. Especially since it's only going to be used for the street and everything else that was mentioned in your dissertation.
P.S. Regarding this scenario:
Your comprehension skills are **** poor. I'll entertain this just for your sake, however. Where did you get the above from this:
If a person wants a Vette and are stuck in the situation you are in then they should make due with what they have and SAVE THEIR MONEY before making such a major purchase. Making due doesn't mean buying "beefier" components on the current car to "beef it up..." You doin't need an Economics degree to figure that out, do you?
Your reasoning would propose that if someone were to want a Corvette, that they should just go out and buy one, because any other car would be illogical if their ultimate goal was a Corvette. You appear as if you would continue to stand behind your argument, regardless of the situation.
Honestly I would just leave the 10-bolt alone and invest the money in a 9" or 12-bolt.
Originally Posted by SGFuryZ
Good job. Way to skip through all the posts explaining the purpose of this thread. BTW, who cares if your friend is on his 13th 10-bolt? As far as I know, he could be excessively hard on his car, not to mention, if he installed those gearsets himself, may not have done so correctly. I've had my camaro 7 years now and have not gone through 13 rear ends. I've only gone through 5, but I found out that these all broke because of a bowed/unbalanced driveshaft. Basically, I told the bodyshop who repaired my rear-ended camaro to check the driveshaft. I assumed they did, and for the next 1.5 years, I'd break a ring & pinion every 3-4 months. When I figured out it was the driveshaft, I had it serviced, but by then it was too late, and this last rear end had been damaged. Instead of hassling with repairing it right away, I decided to wait until it went out to install new gears. It ended up lasting me another 2 years, before it started whining really bad, which I think was partially due to the long-neglected pinion seal leak (lack of lubrication) So, aside from my unbalanced shaft, I would have never broken a 10-bolt in the 7 years I've owned my camaro. Now, tell me again why I'm wasting my money...?
If you actually had some brains you wouldn't spend money "beefing" up a 10 bolt when you said you are going to get a 12 bolt anyway, you should have put that money aside for a 12 bolt. And my friend worked at a rear end shop, so he knows how to set up the gears, and he also had other people set them up to make sure, and he still breaks them every 2 months.
If you don't want to know what people think, don't ask the ****ing question in your post.
If you actually had some brains you wouldn't spend money "beefing" up a 10 bolt when you said you are going to get a 12 bolt anyway, you should have put that money aside for a 12 bolt. And my friend worked at a rear end shop, so he knows how to set up the gears, and he also had other people set them up to make sure, and he still breaks them every 2 months.Anyways, when is Nick getting that 8.8 in there?
Dude, ignore the ****ing moron.
Not any time soon, he broke his crank pulley racing a liter bike friday night, which bounched around and shattered his opti, a bunch of coolant lines, took a fan out, and his radiator, and scored up his crank snout too... I was watchin from the side of the road, I thought he blew up, but it was just coolant/oil getting on the headers... He has alternate transportation right now, so I don't know when hes going to fix it. He doesn't want me to tell anyone what he bought and I don't want him getting pissed at me for tellin everyone, so if you wanna know talk to him...
