Building my 10-bolt up, whatcha think?
Re: Building my 10-bolt up, whatcha think?
Originally Posted by SS RRR
Can you not understand the above? Is it too difficult? If the car is only seeing street duty then there's no point of "beefing up" a 10-bolt. It's money that is just being thrown away.
Originally Posted by SGFuryZ
Are you dense??? First, I'm not asking if you think it's a good idea. I asked you to rate how stout you think it may be with the aftermarket parts I have added to it. I KNOW it doesn't compare to a 12-bolt, but it's certainly better than a "stocker". I was wanting opinions on my combination of parts, as well as any other ideas on how I can ADD to the strength of my 10-bolt. I read somewhere about welding the housing ends better, but I'd like to hear more opinions/ideas. BTW, I've had the OE axles in there, OER crush sleeve, and so forth, and I considered myself to be somewhat hard on my rear, especially with my manual tranny. I've made a number of launches on my ET Streets without a single problem. How? I don't dump the clutch @ 4000+ rpm like some of you retards do. Instead, I feather the clutch @ 2500-3000 rpm (this is where my cam's powerband starts), until I "feel" it to be alright to let her go. Maybe when I'm certain I've got a strong 12-bolt underneath there, I'll be careless and dump the clutch hard with drag slicks. Until then, I'll stick with my 10-bolt. I've ran 400+hp on the same rear for years, and it wasn't nearly as "built" as it is now. Maybe for most of you 10-bolt "haters", you either screwed up the install yourself, or your gear installer wasn't as credible as they claimed themselves to be...
Most EVERYONE has a reason to hate a 10-bolt. Especially those with a manual transmission. They are junk. Plain and simple. They are the same weak POS that comes from the S-10. They were not even close to being designed to handle even the stock torque of a LT1/LS1.
If you've had such success with a 10-bolt that wasn't, "built as it is now.." then what's the point of throwing money at this one? You can buy used 10-bolts for cheap these days.
So you feather the clutch on Streets... Nice... I dump my clutch at 6000+. I reckon that makes me a retard. LOL
Honestly IMO I think you are wasting money if your motive is to eventually get 12-bolt or 9".
I have one solution for you regarding the amount of money you are spending for your wedding.... elope. Congratulations.
Is that so? Tell me, should I have bought GM replacement axles @ $600/pair, or should I have bought the "beefier" aftermarket axles for $250/pair?? Or maybe instead, I should pay a junkyard $200 for a pair of used axles...you do the math. I bought aftermarket axles because they were cheaper than OER, and my OE ones were FUBAR'ed (I mentioned this earlier). I can't believe how some of you people make it as far as you do in life with your logic...
I can't believe there are those who ask for opinions and then scream about the responses.
As far as what you should have done it's up to you. If you want to spend money on a junky 10-bolt with the intention of getting a better diff then by all means... knock yourself out. Good logic there. LOL
Originally Posted by blown94
Amen to that man. But we all like to push the envelope a little, just to see how far we can push it. As fun as it is though, the results are always a bummer. Im working on a shortblock now for a powerdyne kit that I should get about 6 psi intercooled and then adding a 100-150 shot on top of that. I could hack together my spare stock LT1 with some forged pistons and rods and re-use the crank and most likely be ok. But like he said,......why would you go through all that trouble and $$ to risk blowin the whole thing up and f*ckin' up the pistons and rods and possibly the block and heads too. Just hold off a little longer and at least upgrade to an aftermarket crank if not a forged piece and save yourself the headache and woes to come later from being cheap and/or in a hurry NOW. Believe what were telling you, Im slowly learning this myself.
I suppose this should directly apply to a 10-bolt and those, "fu<kin catalog racers.." who want to spend the extra cash on a stouter product, right?
lol @ your simple-mindedness.
As I stated in my original post, as well as being pointed out by ONE observant person, I plan on going to a 12-bolt in the next few years. I know this is not a reliable substitute, but for now, this is what is the most financially feasible. I understand that this is YOUR OPINION, however, you didn't back up your opinion by ELABORATING on your reasoning for holding such an opinion. I can call you an a$$hole, because that's my opinion. Just calling you one wouldn't be very constructive to the thread, but if I simply explained why I felt this way, I'd be more productive in getting my message across. See my point?
As far as refraining from mentioning the wedding, who cares? That's not the point. I stated in the beginning that this wasn't a permanent solution, and besides, since my car is pretty much a "toy" and not a all-out dragster, I think your argument is quite ludicrous. You must understand, I'm 24 years old, still in college, and I work a low-wage, part-time job. This year I'll probably clear $15k. On top of this, I've gotta come up with $2500-$3000 for our wedding photographers, another $3000 on the reception, and we're not even having a honeymoon. We could go to Italy for 2 weeks for $2500...you think my fiancee would be happy if I came home with a 12-bolt and she realizes that we could have had an incredible honeymoon if I didn't just drop $2500 on this silly rear-end? I will be trying to get on with a local police department by the end of the year, so maybe once my income triples, I'll look into that 12-bolt, since by then $2500 will be a lot easier to come by.
I look at it this way.
-You don't go to the track that often
-When you do go, you launch conservatively
-You're running low on cash temporarily
-You're getting a 12-bolt in the future
So MY point is, why bother upgrading/trying to make the 10-bolt stronger when you probably won't even break it in the first place?? Get it?
Oh, and another thing, no matter what you do, you can't really beef up the 10-bolt. The main weakness is the size (7 5/8" ring gear), so no matter what kind of axles, posi unit, gears, etc you put in, it's still going to be weak.
And launching hard makes people retarded? ****, I never knew that! I guess when I flash the stall off the line, I'm automatically considered a retard.
Retarded for the fact that I simply don't care if my 10-bolt breaks, because I see it as an opportunity to UPGRADE TO A 12-BOLT.
If you're not gonna beat on your car you won't need
an upgraded rear end.
They are weak, but contrary to popular belief,
they aren't made of glass....
I agree w/ you somewhat. It's not power or really even torque that kills them, but shock to the driveline. I can't count the amount of threads I've read from here from those who've popped their diff's just from being stupid on the street on street tires and virtually nothing done to the motor.
Lookie here... Hypocrisy? I think so. LOL
No matter how lengthy your post is trying to explain throwing money at a turdy 10-bolt it still won't convince me it's the right thing to do. ESPECIALLY when the primary motive is to save enough money to upgrade.
Is there a reason why you are trying to explain your situation to a "fu<kin catalog racer.."?
BTW.. how many times must you be told a 10-bolt in an auto car will withstand much more abuse than a manual.
You'll be fine. You dont run slicks or even race. The aftermaket axels were the cheapest, good decision.
I wouldnt spend the money on a 12 bolt if you dont race its a waste of money. Just be easy on your current rearend.
In my personal opinion i wouldnt think about a 12 bolt anyways if you really want and to upgrade then get a 9in. Then you can throw the 4.11s in at the track and then put the gas milage gears in on for the drive home. Also a stronger rear imho.
l8r
James
l8r
James
My opinion based on personal experience:
1. Don't bother beefing up a 10-bolt that's not going to see hard use. Drive it til it breaks or you have the funds for the 12-bolt.
2. Cancel the wedding. If she'd rather spend the money on a honeymoon that lasts a week than a solid rear that'll give much longer dependable enjoyment, you won't ever have the extra funds to get the 12-bolt.
I'm a night manager at the local Wendy's. I guess I've made it pretty far!
The whole point of this thread was to ask experienced and knowledgeable members what they thought in terms of my combination of parts, and also asked what other possible ideas anyone might have in terms of further "beefing" the rear end up.
As far as your sarcastic "good logic" remark, you think much too narrowly. Yes, my ultimate goal is a 12-bolt rear, but as of now, it's just not financially feasible for my current budget. Your reasoning would propose that if someone were to want a Corvette, that they should just go out and buy one, because any other car would be illogical if their ultimate goal was a Corvette. You appear as if you would continue to stand behind your argument, regardless of the situation. If someone wants a Vette, but they're in high school, that would be ludicrous to even attempt to make such a decision. Even IF they could afford it, (which they couldn't- not in high school), the cost in insurance would be unreasonable for a person that young. How about another situation? What if some family just had a child and just bought a new house? Should they go out and buy a Corvette? Or should they settle for a more financially reasonable car until their money situation improves? By your logic, people should go out and build their "dream house" they ultimately want to live in for the remainder of their lives, regardless of the situation. Guess what? Most people don't have such opportunities, so they settle for something lesser, which they will slowly "upgrade" until their financial situation is more favorable, and THEN THEY WILL BUY WHAT THEY REALLY WANT.
See, I beefed up my 10-bolt, because I probably won't have that kind of "free" cash available until after my wedding in June. I really would rather not go without my "weekend toy" for 8 months, just so I can buy a friggin' 12-bolt. Instead, I'll beef this one up, because the parts I upgraded NEEDED to be replaced anyways due to damage. So, in other words, my options were: (1) Let it sit for 8+ months until I can afford a 12-bolt, (2) Find a junkyard 10-bolt to slap underneath there for $200-400, or (3) Invest about $500 in my current rear end and drive on that until I can afford a 12-bolt. See, I've already upgraded to some beefy parts before this rebuild, and with these other upgraded parts, this will increase the resale value of this rear end when I can afford to upgrade. In other words, I can now turn around and sell this "built" assembly to someone else, who may be looking for an affordable "upgrade", which will allow me to recoup my losses. I am most certain that my rear end will be in excellent condition when I go to sell it, since I don't really race all that often anymore (my priorities may differ from some of the members here), I NEVER launch hard, and I SELDOM use drag slicks. By going the route I chose, I can now enjoy my car until I can afford a 12-bolt, as well as recoup some of the money I invested in beefing up the 10-bolt. Either that, or when it comes times to go to a 12-bolt, I'll throw this rear end underneath my fiancee's Trans Am, to replace her "mostly stock" 10-bolt. Now, tell me again who here has the "good logic"?
