Broken Posi unit?
Old Mar 2, 2010 | 02:51 PM
henryz28's Avatar
Broken Posi unit?
My car has been having problems with traction; it spins the tires really easy and it did not do this when I first installed the new used 3.42 geared stock posi rear end. So today I decided to hold my foot on the break and press the throttle, I only got the passenger side tire to spin. If the posi were working correctly it should spin both tires; this must mean my posi unit is broken. How much will a stock posi unit run me and how difficult is it to install? Do I need to measure the play in the rear and add shims according to the play, or can I just bolt the new unit in? Thanks
Old Mar 2, 2010 | 08:24 PM
Maybe it means one of your rear brakes is holding better than the other one.
When you just floor it (not playing with the brakes), and the tires break loose, how many stripes of rubber do you leave - 1 or 2?
Old Mar 3, 2010 | 11:36 AM
henryz28's Avatar
I am only leaving one stripe of rubber. And it feels like the car wants to go sideways when I floor it. It sucks, the car felt faster when it used to hook up with the posi unit working. I used royal purple, it said it had limited slip additive so I did not use the GM limited slip additive; could this cause my problem?
football4life
Oct 4, 2015 07:48 AM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
maverickmk
Sep 1, 2015 09:17 PM
