Best clutch recommendation! Quick
Old Jan 22, 2006 | 05:03 PM
  #16
walt355's Avatar
Re: Best clutch recommendation! Quick
Ive got about 7500 miles and around 100 track passes on my spec. It is still holding up the best.
Old Jan 22, 2006 | 07:36 PM
  #17
97 RedSS's Avatar
I'd get a Spec Stage 4..no springs on disc.
Old Jan 22, 2006 | 08:15 PM
  #18
Birdman7389's Avatar
On a mild street car? Thats no fun. Streetability counts, and without the springs, that is even harder on our glass rear-ends.
Old Jan 22, 2006 | 08:16 PM
  #19
njenson's Avatar
yall think i should consider a new flywheel also?
really short on cash though
Old Jan 22, 2006 | 08:18 PM
  #20
194bird's Avatar
i just had mine machined if it does not have a lot of heat spots just clean it up with a buffing pad
Old Jan 22, 2006 | 09:01 PM
  #21
IdahoLT1's Avatar
I had their steel flywheel with my clutch. Havent noticed any difference but the track doesnt open up till april so im not sure. Id be weary with a 100 shot of n20 and a stock rearend. Not totally sure if it could handle it but with that much power opened up instantly id assume its hard on it. I think every performance mod should be accompanied with mods to prevent breaking things. What good is it to put 500-700 in a nitrous system to only use it a few times before replacing a rearend or driveshaft. I was also told the 96 and newer T-56 are weaker. Its not fun driving your car to the track to have it towed home IMO.
Old Jan 22, 2006 | 09:24 PM
  #22
97 RedSS's Avatar
I'm speakin from experience here...I've had both stage 3(has springs) and the Stage 4..I guarantee you can't tell the difference between the two if you were to drive them. I drive my car in Dallas traffic so don't tell me it aint streetable. You know the guy wants to go fast in the future so why not do it right the first time?
Old Jan 22, 2006 | 09:32 PM
  #23
njenson's Avatar
yea, i was going to do it with a safety switch, window switch, and bottle heater
i also dont plan on running it a whole lot but i want a drivetrain to handle it when called upon
i didnt think a 100 shot with the safety stuff could hurt the rear end much though
anyone have any part numbers and what i need for the mcleod clutch?
Old Jan 23, 2006 | 03:48 PM
  #24
njenson's Avatar
anyone?
Old Jan 24, 2006 | 09:39 AM
  #25
1 DWN CAM's Avatar
Originally Posted by 1 DWN CAM
Go with the Mcleod Single disk. good for up to 500hp. 360822 Pressure Plate.
261871 Disk.
I gave it to you on the first page
Old Jan 24, 2006 | 01:55 PM
  #26
njenson's Avatar
thanks
Old Jan 28, 2006 | 11:27 AM
  #27
JonZ28SS's Avatar
Not sure about the SPEC clutches, but I used a Dual Friction Centerforce in my 96 SS and it grips like a bitch without fail. Not sure about long term use because it's 5k miles new, but I'm very happy with it. I also used a new billet steel flywheel hoping for more momentum in gear, which I believe I gained in acceleration. Just my opinion.
Old Jan 30, 2006 | 03:41 AM
  #28
njenson's Avatar
Yea i Got the Mcleod but she is till appart
Turns out some oil got into the clutch so i had to replace the pan gasket (the rear seal looked fine) and i have to go to the dealer or some other shop on monday to get a fork or the fork spring because it is half busted and is only a matter of time before it would have slipped off
Interesting driving the folks 95 suburban for now
same size engine, but different gearing and plus how many thousand pounds
KYWes
Jun 14, 2022 06:52 AM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
jl1ne
Jul 7, 2015 08:38 PM
