Best clutch recommendation! Quick
Re: Best clutch recommendation! Quick
Originally Posted by 97 RedSS
I'd get a Spec Stage 4..no springs on disc.
Originally Posted by njenson
yall think i should consider a new flywheel also?
really short on cash though
I'm speakin from experience here...I've had both stage 3(has springs) and the Stage 4..I guarantee you can't tell the difference between the two if you were to drive them. I drive my car in Dallas traffic so don't tell me it aint streetable. You know the guy wants to go fast in the future so why not do it right the first time?
Originally Posted by Birdman7389
On a mild street car? Thats no fun. Streetability counts, and without the springs, that is even harder on our glass rear-ends.
yea, i was going to do it with a safety switch, window switch, and bottle heater
i also dont plan on running it a whole lot but i want a drivetrain to handle it when called upon
i didnt think a 100 shot with the safety stuff could hurt the rear end much though
anyone have any part numbers and what i need for the mcleod clutch?
Originally Posted by 1 DWN CAM
Go with the Mcleod Single disk. good for up to 500hp. 360822 Pressure Plate.
261871 Disk.
261871 Disk.
Not sure about the SPEC clutches, but I used a Dual Friction Centerforce in my 96 SS and it grips like a bitch without fail. Not sure about long term use because it's 5k miles new, but I'm very happy with it. I also used a new billet steel flywheel hoping for more momentum in gear, which I believe I gained in acceleration. Just my opinion.
Yea i Got the Mcleod but she is till appart
Turns out some oil got into the clutch so i had to replace the pan gasket (the rear seal looked fine) and i have to go to the dealer or some other shop on monday to get a fork or the fork spring because it is half busted and is only a matter of time before it would have slipped off
Interesting driving the folks 95 suburban for now
same size engine, but different gearing and plus how many thousand pounds
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
