Bearing Question
Old Oct 3, 2003 | 07:28 PM
zoomjrl's Avatar
Bearing Question
Hey I was doing doughnut when at the end I hit a curb. Now I get that "sqweak,sqweak,sqeak" sound going down the road. Seam to notice it really well around 20-25MPH. Which bearing do you think I damaged and do you think I bent the axle too? Damage to the wheel is crack about 5 inches long at the lip of the wheel, and pushed it a little. I didn't hit the curb that hard, I was very surprised to see the wheel cracked, figured it would have only bent it. Also, do they make stronger axle bearings, I know they make stronger axles, cause this is my second curb accident, and I don't plan on making it a trilogy but if there is stronger stuff I'd rather put IT in then put the same thing back in.
Old Oct 11, 2003 | 08:50 PM
Rodrigues's Avatar
You possibly bent the axle and you probably need new axle bearings with it... You may want to lift the rear in the air with the car in drive to see what might be out of round.
Sergio
Jan 27, 2016 04:27 PM
warmeck
Mar 8, 2015 08:01 PM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
