Bars in rearend don't know what they are.
Old Mar 13, 2009 | 10:45 PM
Robwhartlt1's Avatar
k I have two bars that are not stock in my rearend. On the left and right there are 2 bars that go from the frame to the rearend. And then one that long ways that goes at an angel from one side to the other that says eddlebrock if you know what these are let me know thanks.
Old Mar 14, 2009 | 12:51 AM
Angelis83LT's Avatar
the two going from the frame to the axel (1 on the passenger and one on the driver's side are your lower control arms, and the one going at a diagonal is more than likely the panhard rod/bar.
Both things are stock equipment on fbodys, yours might just be upgraded.
Old Mar 14, 2009 | 08:20 AM
Yea I had a parts car and they did not look the same mine have more meat on them.
Old Mar 14, 2009 | 08:35 AM
JakeRobb's Avatar
Super Moderator
It's quite common to upgrade the lower control arms and the panhard bar.
Old Mar 14, 2009 | 12:14 PM
what dose it help
Old Mar 14, 2009 | 12:39 PM
JakeRobb's Avatar
Super Moderator
Originally Posted by Robwhartlt1
what dose it help
Along with the torque arm, those three bars hold the rear end in place. Upgrading them adds strength and stiffness, which permits harder and more consistent drag launches. Depending on exactly which ones you have, it can also might allow you to adjust the position of the rear end.
Old Mar 14, 2009 | 12:44 PM
ok so than thats good
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ddr698
Jan 9, 2015 10:05 AM
