bad tft sensor
Old Jun 28, 2008 | 01:47 PM
red 95 z28 lt1's Avatar
bad tft sensor
i checked my wireing and connections to the trans and it seems that my tft sensor is shot, i have no lockup when in OD my trans shifts early to 2nd and when i shift to 3rd it shifts late, sensor always reads -40
where is the tft sensor located in the trans? does the valve body have to come down? i know how to work on cars but i never dropped my trans pan before.
how do i go about changing this? is there any pics of it?
Old Jun 29, 2008 | 02:52 AM
xtremetrans's Avatar
The tft is located in the pan on the tran pressure switch assembly. It is easy to change, just pull the pan and replace the trans pressure switch assembly, it is the switch which is held by 3- 10mm bolts and 2- 8mm bolts. I can email you a picture of the switch if you need.
Old Jun 29, 2008 | 08:22 AM
a picture would be great if you could email it to me, my address is motirman7@aol.com
where can i get one of these sensors?
Old Jun 29, 2008 | 05:46 PM
ok i got it out i did a google search on it. is there any way to test it with a meter to see if its bad, im probably just going to replace it anyway
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
