Auto tranny fluid leak...
Old Dec 10, 2003 | 01:33 PM
texasTA's Avatar
I have a definate tranny leak coming from the tranny. I believe it is coming from the rear of the tranny. What seals are on the tranny that could be leaking? Is there anything else to check as to where/why the tranny fluid is coming from?
Old Dec 10, 2003 | 02:48 PM
ChevyCamZ28's Avatar
If it's coming from the rear of the tranny, then it is the driveshat to tailhousing seal, that's the seal where the driveshat slips into the transmission. You can easily pop the out and put in a new one. If it's not that it might be the pan gasket leaking and the wind is blowing the oil to the back.... but my guess would be the tailshaft to driveshaft seal.
Mike
Old Dec 10, 2003 | 03:01 PM
texasTA's Avatar
What would that seal be called? I just got off the phone with O'Reilleys and they show two differents parts that might apply. The first is called "rear seal" for 3.29
or they have the "rear exit seal" for 7.99
I could look in my Chilton's later tonight, but I was planning on stopping by the auto parts store on my way home. Thanks guys.
Old Dec 11, 2003 | 12:24 AM
90rocz's Avatar
Rear seal, it's the most common one due to overfilling and driveshaft vibration, from worn U-joints or out of balance.
It's a doughnut looking seal.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Hobbyguy
May 26, 2015 02:15 PM
tds1213
Nov 27, 2014 12:55 PM
Snoman73
Nov 17, 2014 07:22 PM
91 Redd Sledd
Aug 25, 2002 03:27 PM
