Auto shift problems
Old Sep 23, 2010 | 03:16 PM
silverz28's Avatar
Auto shift problems
I have a 96 z28. I just changed my flexplate. During the process, the transmission fell off the jack. Not all the way off but most. After cleaning up the spilled fluid, I did an inspection of the transmission and its wires. Everything looked good, so I put it it all back together. Now when I drive the car, it wont shift. It goes in reverse fine but 1,2,3,4 are all the same. I,m not sure what forward gear it's in when driving forward. Feels like second but not sure. What are some things I can look at? I did refill with fluid.
Old Sep 24, 2010 | 08:58 PM
silverz28's Avatar
I scanned with datamaster and no codes came up for the trans. I hooked up datamaster and while in the garage with the brake on, went through all the gears. Datamaster reads that I am going to all the gears. Any ideas why it is not shifting properly in the forward gears?
Old Oct 7, 2010 | 09:34 AM
marshall93z's Avatar
Ever find out the problem? Mine is doing the same thing... although mine is definitely in first gear... just won't change out of it.
Old Oct 7, 2010 | 03:53 PM
silverz28's Avatar
Not yet. I'm going to check the wiring when I get a chance.
Old Oct 7, 2010 | 08:03 PM
lt1-xjs's Avatar
The 6 speed or the auto ?
Old Oct 12, 2010 | 04:25 PM
Auto. 6spd is gone.
Governer gear was stripped in the auto, which let me shift out of first, but then I found out the tranny was toast! Slipped into third and never would go to 4th.
Old Oct 13, 2010 | 03:50 PM
silverz28's Avatar
Found it. The VSS was unplugged.
Old Oct 14, 2010 | 02:03 PM
Sweet! Simple fix!
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
Sarahrope64
Nov 27, 2014 11:17 AM
