Anyone know where to get an axle vent?
Old Feb 7, 2010 | 01:21 PM
z28 justin's Avatar
I think the axle vent on my S60 is bad. Had some leaking fluid out of the axle ends. Tried to spray it with brake cleaner and put some compressed air through it. Most of the air was pressed back out instead of through therefore leading me to believe the vent is just not good. Anyone know where I can get another (it's a bolt with some mesh, pic below)
I've tried Autozone, they said they didn't have one. Anybody else ever replace one of these?
EDIT: Sorry, I thought I posted this here before but couldn't find it. Also, bump....
Old Feb 10, 2010 | 06:47 PM
z28 justin's Avatar
I have found a solution to my Strange Dana 60 Vent problem.
I started shopping around for fuel filters and when I got to Autozone started looking through the fuel filters, I found one with a threaded end. I pulled the Strange axle vent out and checked the width, they appeared to be the same. For $4, it didn't really matter. I get home and tried it out and sure enough it fit!! Pics below
Here is the fuel filter next to the vented bolt Strange put on the axle
Here is the part number if anyone else wants to do this and not worry about popping seals in their new $2K axle.
Here's what it looks like on the axle.
I'm thinking about cutting the nipple for the fuel line off since I don't need it and it will look a little better (just need new batteries for my Porter Cable saw).
Old Feb 11, 2010 | 09:03 AM
mzgp5x's Avatar
I had same problem on a Moser 12. I had fluid filled too high. I had to replace the wheel bearings due to leaks. I mounted the vent (Summit racing) high above the axle w/ flex hose. It worked. B.
2QUIK6
Sep 17, 2016 02:31 PM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
tdigger9899
Sep 7, 2015 10:56 AM
Jul 10, 2015 02:23 PM
