Anyone breaking th400 cases
Old Sep 19, 2007 | 11:52 PM
sleeperz28's Avatar
I got about 7 passes out of mine before i busted the gear lugs. Im not sure how common this problem is being that my car weights in at 3700 with me in it@1200rwhp
I found this on the net. http://www.atfspeed.com/products.html I might grab it if i break another case. Just wondering if any others have this problem.
Old Sep 20, 2007 | 10:07 AM
Baxter pushed 1,350HP through an Art Carr TH400, with complete reliability.
Old Sep 20, 2007 | 03:19 PM
Performabuilt's Avatar
Supporting Vendor
I have only seen this happen as a result of excessive line presure well beyond whats needed and or complete elimination of the accumulator for second gear. I suppose you could get a weak case that could have been weakened by time or the previously mentioned conditions but I have not run into that myself ussally its and instant failure resulting from one of those conditions.
Old Sep 20, 2007 | 05:02 PM
sleeperz28's Avatar
what kind of line pressure should this thing be at? I still drive it on the street from time to time to the local hang out
Old Sep 20, 2007 | 06:22 PM
Supporting Vendor
Had to look that up mostly mess with OD trans now but the chart in alldata says 150 psi in drive should be max you can test by unhooking modulator and place the guage in the presure port.
Old Sep 20, 2007 | 07:49 PM
12SCNDZ's Avatar
Most likely the pressure is too high.
Frank
CPT
Old Sep 20, 2007 | 09:05 PM
Pro Built Automatics's Avatar
Anything over 195psi. (Trans Brake) can cause this. I like 175-185 psi. max. Removing the waved steel, eliminating the accumulation, using the stock snap ring in the case against the lugs can contribute to this. Jerry the owner of jTCS in Chino, California (909 6278595) machines the case (you have to send him your case) to accept a spiral ring. This allows cases that have the lugs broken out to be used again. This is good, since the TH400 cases are getting harder to find.
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
