Aluminum Flywheel...balancing
Aluminum Flywheel...balancing...weights
If a aluminum flywheel is to be purchased (fidanza) how do I go about balancing this thing? is it necessary? it comes with weights, my machine shop says they don't do balancing...I just need it balanced the same as the factory one? thanks for the help
I have a stock rotating assembly and the fidanza flywheel says it has to be "counter balanced" like our stock flywheel. I just need to know what is needed to match this aluminum one to my stocker.
Now on my new clutch with the mark on it that is supposed to line up or get very close to the X on the stock flywheel, do I line the cluch up to the weight on the aluminum Fidanza flywheel? thanks guys
well I installed the flywheel with the supplied weight in the same spot as the weight on the stock flywheel and put the pressure plates mark in the same spot it would have fallen on the stock flywheel. The motor has a vibration, it is small but there....out it comes again...
CARiD
Sep 30, 2015 05:44 AM
