aluminum driveshaft
aluminum driveshaft
I have a 1LE aluminum driveshaft left over from my IROC that I'm not using...upgraded to a stronger unit in that car and have a stock steel driveshaft in my M6 '94 Z. The driveshaft has new spicer u-joints and I was wondering how strong these units are. Anyone know if it's a good idea to use it? I drive this car daily and would hate to toss a driveshaft 400 miles from home.
I've been running an LPE Aluminum driveshaft (which is probably a 1LE) since 1995 with the original U-joints with no problems...and I make 420rwhp...durability with this unit has never been a problem. With the aluminum you drop rotational mass on the driveline and every little bit helps...
--Alan
--Alan
Forgot to mention that this is a 1LE shaft out of an '88 IROC 1LE car...so it's the same length but a different diameter without the dampening ring. I've never heard of anyone running a thirdgen shaft, which is why I'm asking...how do the thirdgen aluminum driveshafts compare to the fourth?
Good...mine's the 2.75" driveshaft, I wish I had a 3.5 aluminum one...but this one will do. It's fairly heavy for aluminum but not as heavy as a steel shaft. I'll put it in, probably just as strong as the steel one that's in there now especially since the steel one I have now has a u-joint going out)
Originally posted by BiGGinZ
What about the carbon ones? I have seen those for sale everywhere.
Rich Krause
What would you say the limit of the smaller 2.75" shaft is? I dont want to be pushing the limit, but I dont plan on any sticky tires or anything. Just a street driven M6 with heads and cc306. I drive to south FL often but I do tend to be aggressive on the gas sometimes so I dont want to be left in the cold with a shriveled shaft
Rich Krause
