Advice Needed!
Old Nov 7, 2003 | 03:22 PM
sidewayz28's Avatar
Advice Needed!
Recently inslalled a b&m shift kit, now i have a grinding noise in the rear end. could it be an inner axle bearing? Haven't checked the outer ones yet. If it is an inner bearing, is it something easy that I can replace myself or is it very technical? any input would be appreciated:
Old Nov 8, 2003 | 07:19 PM
2000zee28's Avatar
You need to describe the grinding a bit more/ Is it all the time, around turns, during hard driving? What years your car? If 98 or newer Zexel Torsen carrier 97 or older Auburn carrier? By inner Axle bearing you must mean carrier bearing. Does the car shift O.K? Give some more info
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
1775.Z28
Jan 11, 2015 10:51 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
