adjusting stops on the Pro 5.0 shifter
Old Dec 17, 2003 | 04:24 PM
shawnberry50's Avatar
how do you guys do this?? thanks!
shawn
Old Dec 17, 2003 | 04:53 PM
Ken S's Avatar
Shift to first, adjust the top point So there's the slightest little gap.. Shift to 2nd, adjust the botom point so theirs teh slightest little gap.. shift to 3rd, and if more travel is needed, adjust it.. shift to 4th and if more travel is needed, adjust it.. etc..
prob won't hurt to use some threadlock to make sure they don't move.
Old Dec 17, 2003 | 05:50 PM
drasgear's Avatar
I may have been given bad advice, but I was told to shift into the gear adjust until it touches and go 1/4 turn more. I was told this is to prevent "overshifting" under hard throws which may lead to bent forks (since ours are aluminum). Like I said, I am not a tranny expert or anything but that is what I was told by a guy at the track.
Old Dec 17, 2003 | 06:01 PM
Ken S's Avatar
Yup, thats exactly what I did... except that I didn't want it to rattle/vibrate, so I gave it just a hair of a gap. plus you want to make sure that in each gear, you gave enough travel. Since there are only two stops, you have to pick the best out of the 3 gears for each.
heh, i figure worse comes to worse, I'll just bend the shiftfork that extra millimeter.
some poeple just take them out totally since supposidly our trannys have internal stops!
Old Dec 18, 2003 | 02:36 PM
chpmnsws6's Avatar
you were told correctly! i've had mine in for awhile and beat the tar outta it, never a problem yet!
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
