a4 to t56 conversion!
Old Jun 1, 2007 | 09:12 PM
  #16
v8 FC's Avatar
hottest want to swind down and give me a hand with my tranny swap
Old Jun 4, 2007 | 08:35 PM
  #17
HottestZ28's Avatar
I def would but I am extremely bad with directions and I could def help you as much as i can with questions or comments
Old Jun 4, 2007 | 09:13 PM
  #18
v8 FC's Avatar
lol its cool i am just going to take it to the shop for some reason the flywheel clutch and pressure plate bolt in perfect the bell housing perfect but the tranny itself doesnt go in at all leaves me about 3 inches hanging out
Old Jun 4, 2007 | 10:02 PM
  #19
v8 FC's Avatar
i tried it jabroni! i think its my pilot bearing and i don't have the tool to remove it or put it back. aka going to the shop
Old Jun 5, 2007 | 08:36 AM
  #20
v8 FC's Avatar
well since you like to beat on things you should swing over
Old Jun 6, 2007 | 01:19 PM
  #21
izzyz28's Avatar
Originally Posted by Z28Roxy
Just keeping pounding it in there. It's either that or your clutch isn't perfectly aligned.
This is probably the culprit, but you also want to make sure that the trans and engine are in a straight line while you're pushing it toward the engine or it will NEVER engage. My guess would be that you will have to loosen the PP and align the clutch disc again with an alignment tool. When it is right the tool should take zero pressure to insert and remove.
Old Jun 7, 2007 | 10:36 AM
  #22
v8 FC's Avatar
yeah we are going to try it again over the weekend and see what happens. thanks for the info
Old Jun 7, 2007 | 08:50 PM
  #23
HottestZ28's Avatar
yea I had the same problem, I ended up shaking and taking up the slack alittle at a time till it was tight. DONT FORCE IT IN JUST TAKE UP THE SLACK IN THE BOLTS EVENLY.
Old Jun 8, 2007 | 12:38 AM
  #24
v8 FC's Avatar
i can't even get the bolts to get that close. i don't know what i did that is why i am going to just take it to a pro to do!
Old Jun 8, 2007 | 08:50 AM
  #25
Jazsun's Avatar
I wouldnt use the bolts to force it in, sounds like a bad idea. I had that problem, first time because the pp was incorrect. Also make sure the clutch fork is not in the way of anything. All else re-allign clutch using the tool. Usually it takes some wiggling once it gets up there and some pushing from the rear of the trans, while someone support the front from sagging.
Bxlt1
Sep 29, 2015 03:18 PM
Henson071
Sep 18, 2015 04:01 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
tdigger9899
Sep 7, 2015 10:56 AM
