A4 Oil and filter change how to ?
Old Oct 6, 2004 | 11:01 PM
Spllouder's Avatar
ok i need to change my trans fluid cant afford to have it flushed. whats everthing i will need ? and how do i do it? i never changed a trans fluid before . I know i will have to drop the pan but wheres the filter ? and any thing else i could do while the pan is off ? A a4 how to will help alot cant find one . Thanks
Old Oct 6, 2004 | 11:21 PM
n2ceptor's Avatar
Re: A4 Oil and filter change how to ?
If you just want to drop the pan and replace the filter..... Get a filter kit(filter/pan gasket) for a 4L60E trans and 5 quarts of Dexron III.... The pan has 17 bolts( if I remember right), When removing the bolts start in one corner, you want the pan at an angle for the fluid to pour out.... Take your time taking out the bolts, or you will have a big mess... Allow the fluid to drain slowly from the pan angle into an oil pan...
There will still be fluid in the pan once removed, so keep it level when removing the last couple of bolts... Clean the pan with carb/brake cleaner, scrape off any gasket material and allow to dry...
The filter is pressed in and easy to remove and replace....
If you look at the new gasket, you will see 4-5 holes alittle smaller than the others.. This is for holding bolts in place when replacing the pan and it keeps the gasket in place... DO NOT use silicone....
This procedure does not replace all of the fluid, since transmissions hold about 10-12 quarts...
Old Oct 7, 2004 | 12:09 PM
Spllouder's Avatar
thx seems simply Can all this be done from drive up ramps ? will i have enough room to work ?
O ya and wheres the fill hole ? is it in same place as the m6's ?
Old Oct 7, 2004 | 06:53 PM
n2ceptor's Avatar
1. Yes
2. Yes
3. You put the fluid in where the tranny dipstick is.. Pour in 3 quarts, start engine, allow to warm, shift thru gears, place back in park, check level(while engine is running), if fluid is needed then stop engine, add fluid(if needed), and go thru the it again until correct fluid level is achieved...
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Dmonty
Jun 2, 2015 11:19 PM
30thZ4C
Dec 26, 2014 05:09 PM
Jul 4, 2005 05:00 PM
