97 4L60E slippage...or something...lol
Old 07-29-2007, 02:57 AM
blahster's Avatar
So i have this 97 Z28 over here in japan...now keep in mind it is identical to the us version...
but i have a question on the trans...
i have a tendency to manually shift my trans...i know...it's hard on them...but eh...
now, if i manually control the trans, in every gear, as soon as i let off the gas the trans or converter or something slips...and then it will catch itself when i give it gas...but when you let the computer shift, you barely ever feel it slip?
any possible reasons for this...aside from my manual shiftin it?
blahster is offline
Old 07-29-2007, 03:45 PM
MyShibbyZ28's Avatar
what do you mean it slips? that's a very vague term to use, especially over the internet. What is 'it', what does the car do, what does the engine do?
If you are manually shifting at a higher rpm then where the computer shifts at, it will be a firmer shift almost every time. and if you let off the gas at a higher rpm and shift, it might 'feel' like it's slipping, but it's really just high rpm, and the engine being bogged down.
MyShibbyZ28 is offline
Old 07-29-2007, 06:07 PM
blahster's Avatar
ok...say i am driving along in first gear....and let's say at around 3000rpm i let off the gas, normally the car would start to slow down as there is no throttle being applied basically using the engine to slow the car down.... BUT, in my case, the rpms drop all the way down to idle. then, when i give it gas, and the rpms climb back up to where they were...then it catches and takes off....does that make sense?
blahster is offline
Old 07-29-2007, 06:40 PM
12SCNDZ's Avatar
The lugs on the over-run hub, of your input sprag, are broken off. This is a COMMON problem with manually DOWNSHIFTED 4L60E's.
Time to get it rebuilt, and change your driving habits.
Frank
CPT
12SCNDZ is offline
Old 07-29-2007, 08:56 PM
blahster's Avatar
time to sell the car! not gonna be driving it for the next 2 months and then i leave japan a month after that...lmao! time to sell it and get some moolah for it...don't have the dough to get it rebuilt....the shipping charge alone would kill me....lol!
thanks for the info Frank!
blahster is offline
Parts Wanted
05-01-2016 10:25 AM
blac94Z
11-04-2015 01:59 PM
Mikes 1994 z28
10-10-2015 07:55 AM
football4life
10-04-2015 07:48 AM
SEOJustin
09-24-2015 04:39 PM
Quick Reply: 97 4L60E slippage...or something...lol
