94 lt1 to t5 tranny?
Old May 3, 2010 | 11:37 AM
flip617's Avatar
I have a 94 lt1 that came from an automatic. I want to put it into my 95 camaro 5 speed. What will I need to change and wil this tranny work?
Old May 3, 2010 | 03:57 PM
If you can get it to work, it probably won't last long. It's just not robust enough to be behind an LT1. You might want to rethink your position.
Old May 3, 2010 | 04:40 PM
The T5's torque capacity is less than the stock LT1 torque rating (325 lb-ft). Might hold up in moderate driving conditions, but if you're going to speed shift it, bump up the HP, or use sticky tires, you need a T56.
To figure out how to put an LT1 in a V6 chassis, look at the "sticky" on engine swaps on the "V6 Tech" forum. You will need a V8 K-member, PCM, wiring harness, springs, etc. Unless your V6 has rear disc brakes and a limited slip differential, it would be a good idea to find a good used V8 rear axle assembly, since both were standard equipment on the V8's.
Noer
Feb 28, 2015 11:29 AM
importkiller94
Jan 17, 2015 09:03 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
