94 4l60e in a 97 not compatible??
Old Mar 8, 2005 | 06:03 PM
acid5868's Avatar
I post an issue getting a code of p1860 after the swap.
Well after a few more hours of searching I think I found what my problem is.
Apparently only 95+ 4l60e have the TCC PWM Solenoid. Just found out that the tranny I put in was from a 94. Explains alot, guess I need to start looking for another trans or eplore the possiblities of changing over to a th350/400 for future us.
Only thing is now I am wondering seeing how the trans does not have one is it going ot hurt it at all if I drive the car..lol. Can anyone confirm this or am I just trippin?
Old Mar 8, 2005 | 10:14 PM
Drag Bear's Avatar
Re: 94 4l60e in a 97 not compatible??
I think you will be just fine with what you have. This trany has the non pwm pump so there is no solenoid to control. I just picked up one for my 96 TA for a spare.
Is there a reason you think it may not work? You may get an engine code but I think a programer can turn it off or put a reristor in the wire to fool the computer.
Please let me know how you make out, Rick Abare
Old Mar 9, 2005 | 07:56 AM
acid5868's Avatar
not too sure on any findings, seems every where I look it gets quiet as a mouse...lol. I just hope I can figure it out or get some advice, last thing I want to do is burn up another tranny.
Now that I have concluded its a 94 non-PWM tranny is it possible to still use it? I thought there were other issues besides just throwing a code. I will say you know have me curious if a program such as Ion could program it out of the ECU.
Old Mar 9, 2005 | 05:25 PM
12SCNDZ's Avatar
The '94 trans should still operate OK, but you'll need to trick your computer to get rid of the SES light. I hope you used a '94 style torque converter, though. The '97-up uses a different converter clutch lining, that will cook if you try installing one in an earlier unit.
As for the 350/400 option? A 350 isn't ANY stronger than a properly built 60E. A 400 swap isn't neccessary unless you plan on running in the 9's.
Frank
CPT
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
