9 Inch posi type?
Old Jan 23, 2005 | 10:59 AM
lt1nova's Avatar
9 Inch posi type?
I have a 9" ford rearend in my car and I need to put a posi in it. I was looking at the Detroit TrueTrac unit. Does anyone have any expirence with one of these? Any other recommendations on a posi unit?
Thanks,
Old Jan 23, 2005 | 11:48 AM
1BAD86Z's Avatar
Re: 9 Inch posi type?
Thanks,
The true-trac is the same as the torsen. A torque sencing diff. that applies the most torque to the tire with the most traction. Alot of road racers like them cause they come off the corners easier that an auburn or locker. Nascar uses them and they will handle 700hp +.
Old Jan 23, 2005 | 12:49 PM
87DJP2001's Avatar
Thanks,
Forget about a Posi (short for GM"s Positraction Limited Slip), you are looking for a LIMITED SLIP unit.
Old Jan 24, 2005 | 12:38 AM
RedWS6TA's Avatar
if it doesnt see just see a lot of street time just go spool cheaper than a posi and will launch a whole hell of a lot harder trust me
Old Jan 24, 2005 | 09:24 PM
my94blackz's Avatar
Wouldnt recomend a spool
Old Jan 24, 2005 | 09:34 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
If you want better than 31 spline axles, you are limited to a detroit locker or a spool.
If you can live with 31 spline axles, I've been told that the Detroit truetrac is the best option (that is what I'm going with), but it is not really intended for hard launches at the dragstrip.
Old Jan 24, 2005 | 09:56 PM
1BAD86Z's Avatar
[QUOTE=INTMD8]If you want better than 31 spline axles, you are limited to a detroit locker or a spool.
Wrong, you can get a ARB in 35 spline.
Old Jan 24, 2005 | 10:06 PM
INTMD8's Avatar
Well, I thought we were talking about regular differentials.
I know I would never use an ARB air locker in my car. Unless I was going to convert it into a rock-crawler.
Old Jan 24, 2005 | 10:32 PM
lt1nova's Avatar
The car is mostly street, with an occasional drive to the strip. I do not plan on using slicks and I do not need more than 31 spline axles.
I want to be able to go around a corner, accelerate and not burn the inside tire, either get traction or slide sideways depending on the situation and desired outcome.
Hal Fisher
Sep 30, 2015 09:03 PM
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
