700-r4 trouble
Old Aug 3, 2004 | 10:42 AM
BaDDAss90RS's Avatar
Angry 700-r4 trouble
i have a 90 rs with a 305 tbi and a 700-r4 auto tranny. lately its been having problems shifting. it wont shift untill it gets way up in the rpm's and then goes to the next gear, even durin normal driving. ill be doing 25 mph by my hoouse and running like 5500 rpm. ive tried adjusting the Throttle valve cable and that didny help, and ive had a couple ppl tell me it could be a modulator valve that runs off a vacuum hose, but i cant seem to find one at any parts stores. if anyone can help me id appreciate it.
thanx
chris
Old Aug 3, 2004 | 09:46 PM
Pro Built Automatics's Avatar
Re: 700-r4 trouble
If this happened all at once, then a broken governor gear will do this.
Old Aug 4, 2004 | 01:15 PM
Re: 700-r4 trouble
ok...how much would that cost and how hard is it to change?
Old Aug 6, 2004 | 06:23 AM
Re: 700-r4 trouble
Pull off the governor, pull out governor & take it to the local transmission shop & have them install a new governor gear. $5.00-$10.00 should cover the cost. Be sure to install a new cover seal.
Old Aug 7, 2004 | 10:38 PM
thor337's Avatar
Re: 700-r4 trouble
i have a 91 z28 with a 700r4. lately it has been slipping real bad between gears, usually only when i get up on it. but it has been getting worse. is this something small that can be fixed or are we talking about a transmission rebuild.
Old Aug 8, 2004 | 07:57 PM
Re: 700-r4 trouble
You are talking about a transmission rebuild.
Ericksd
Jan 20, 2016 06:07 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Schul365
Aug 22, 2015 10:00 AM
Aug 7, 2015 01:26 PM
surreybrad
Jul 5, 2015 10:36 PM
