7.5 ring gears
Old Aug 20, 2007 | 03:22 PM
kline454's Avatar
7.5 ring gears
WEll i just broke my first ring gear after about 10 or more 10sec passes,it knocked a tooth off the ring. i had the summit ring and pinion gears. My ? is are richmans better than summit or motive exc. who makes the best ring and pinion gears?
Old Aug 20, 2007 | 03:38 PM
jay_lt4's Avatar
if you are running that quick you really should upgrade to a larger rear end
Old Aug 20, 2007 | 04:03 PM
wrd1972's Avatar
OMG get a 9" and be done with it.
No 10 bolt gears will hold up to 10 second passes. Throwing good money on bad money IMHO.
Old Aug 20, 2007 | 04:07 PM
kline454's Avatar
haha i have had to many people tell me it cant be done at wont last,and im out to show them how its done, I been running this rearend for 6month with no problems, 100% stock just gears so now im going to do a few upgrades and see if i cant make it last.
Old Aug 20, 2007 | 07:24 PM
wrd1972's Avatar
Respectfully, you have a nice fast ride and 10's are for most of us to envy, but if you are on a mission to prove the f-body community wrong by successfully using the 10 bolt while running 10's then you efforts and dedication IMHO are misguided. At best you may get lucky a couple times but its like a 800 pound monkey on your back, you will eventually get squashed and have to figure out how to get home. Plus there is a chance the rear grenades and you miss a shift, bye bye 10 second motor.
Obviously piece of mind of knowing you wont blow your rear out on the street or at the strip are worth a certain dollar amount. I personally don't understand why you would spend the money to go tens and not spend the money to properly get the power to th ground.
Us guys only running 12's are the one that have a slim chance of proving the nay sayers wrong, but I personally would limit my efforts from what the members here have posted in the past.
I will now get off my soap box.
Old Aug 20, 2007 | 09:08 PM
kline454's Avatar
yeah i know what you mean and im going to try a few upgrades to the rearend and if it goes out oh well. then i look at a 12bolt but i want to give the 7.5 a fighting chance and see what i can get out of it. with a little luck im going to try and put it into the high 9s with more spary yet this year.
Old Aug 21, 2007 | 06:19 AM
C_Rules's Avatar
check out the bulletproofing your 10bolt thread. i'd like to see how your 10 bolt holds up after doing the tube brace mod.
DirtyDaveW
Mar 15, 2015 07:01 PM
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
