4L60E whining tranny problem
Hi I just wondered if anyone know what was causing my whine problem in park and neutral. If you just start up the car cold it's fine it goes through all gears fine but if you put it in neutral or park it will whine. it desn't seem to affect the performance of the transmission just an annoying and embarrasing whine when you put it back in park. If you wait a while after you've shut the car off and let it cool over 1 hr you can start it up and no whine again. Tried replacing the valve body and seperator plate and checked the passages on the other side of seperator plate for buildup and didn't see anything. any ideas?
so is the converter on it's way out or just being noisy. I've been running the car for a couple weeks now it doesn't seem to be getting worse but still there, and no effect on the rest of it's performance. Then my question returns of why doesn't it do it all the time when I start it up only after I've gone through gears. Then once I park it will make the noise until I shut it off and it cools down. Very strange to me.
