4L60E temp question ???
Old Oct 30, 2007 | 07:42 PM
94heritageZ's Avatar
I have an Autometer trans temp gauge from 100-250 Deg. I put
the sender for it in the pressure test port . My question is the
gauge shows the trans running at 250 Deg after a short period
of driving I felt the trans pan and it was only warm to
the touch . Whats going on here ? Thanks
Old Oct 30, 2007 | 08:22 PM
Performabuilt's Avatar
Supporting Vendor
Thats not and acyrate place to take the temp the fluild there is at its hottest point and the fluild is staionary there it comes to a dead end and sits, You are actually coming closer to measuring the temperature of the case which is also heated by the engine and exhaust than the actual trans temp , sender would be better in the PAN
Old Oct 30, 2007 | 09:11 PM
Moshbmx1's Avatar
I have mine in the same spot and it only reads 150-180 most times
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
