Bad syncro?
Old Oct 25, 2007 | 01:16 PM
dannyum89's Avatar
Bad syncro?
Hi guys. This problem just happened out of nowhere, no warning signs. I pull out of the driveway yesterday morning, I put it in reverse without problem then shift into first without problem. When I tryed to go to second it made a grinding sound but went in. Since then it does it everytime I go into second. Even if im sitting at a red light I can put the shifter into second without pressing the clutch. It wont go in but it grinds as if it wants to go in. Once im rolling I can get it in second but that grind is annoying. Sounds like the tranny is gonna have to come out but opinions on the problem would be appreciated.
Old Oct 28, 2007 | 06:07 PM
OBE1 95Z28's Avatar
If it's isolated to second gear then I agree with your diagnosis that it's a bad syncro.
Old Oct 30, 2007 | 04:29 PM
dannyum89's Avatar
I can get an old T56 from a 95 Viper. Would this fit or would I get the same problem as trying to fit one from a 98 up F-body?
Old Oct 31, 2007 | 09:46 AM
OBE1 95Z28's Avatar
Do a search on Viper trannys, I believe the input shaft is a different diameter.
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
