4l60e not engaging in gears
Old Mar 31, 2009 | 09:26 AM
mrownage426's Avatar
Car does not reverse or drive in respective gears. Whenever the car is put into gear, and then put back into park there a grinding noise. Fluid looks good. Ideas?
Old Mar 31, 2009 | 11:52 AM
12SCNDZ's Avatar
Is the speedo going up with the car in drive...(Eventhough the car isn't moving)?
Frank
CPT
Old Mar 31, 2009 | 11:59 AM
Performabuilt's Avatar
Supporting Vendor
Broken output shaft,stripped splines in yoke or Rear end would be suspect.
Driveshaft yoke or rear most likley if as Frank mentioned the speedo is going up and the car not moving
Old Mar 31, 2009 | 01:17 PM
yes the speedo steadily increase, but the car is not moving. Also when i put it back in park it made a not so good noise.
Old Mar 31, 2009 | 04:09 PM
12SCNDZ's Avatar
You've got a broken rear (differential). the rreason you hear the ratcheting noise when you put it in park is because the transmission is still turning, when it's trying to engage the park dawg into the rear ring gear.
Frank
CPT
Old Mar 31, 2009 | 04:25 PM
i guess this could be a very good excuse to step up to 3.42 or 3.73s
Old Mar 31, 2009 | 04:54 PM
12SCNDZ's Avatar
See. every cloud has a "silver lining"
Apr 16, 2015 09:57 AM
KYWes
Apr 15, 2015 07:28 PM
thenewkid
Apr 12, 2015 07:42 PM
tds1213
Nov 27, 2014 12:55 PM
Zone
Jul 29, 2002 07:43 PM
