4.10 lowest differenial ratio?
Old Nov 30, 2003 | 05:26 PM
NewbieWar's Avatar
is the 4.10 the highest lowest ratio?
Old Nov 30, 2003 | 05:41 PM
Gloveperson's Avatar
I've never seen anything for sale on LT1's that is larger than that. I had 4.11's on my 69 SS.
I can only imagine the mpg on something larger than with an A4.........
Projectz28's Avatar
Moderator
I would assume you are talking about a 10 bolt... the answer is no. There are a few others available but in a 10 bolt they get pretty thin and greatly compromise the strength.
Old Nov 30, 2003 | 05:45 PM
NewbieWar's Avatar
on a stocker car, (2.73) what would be the likely time of an upgrade to 4.10?
Old Nov 30, 2003 | 06:20 PM
DrivinSidewayz's Avatar
if youre talking about your car, id recomend 3.73's for your auto, unless if you dont care at all about gas milage, and i mean pretty bad milage with 4.10's, plus i you would have way too much gear without traction, then you get traction and blow your rear, your auto tranny already has alot lower gears than the 6 speed,
and the best time to upgrade gears, is whenever you wanna have more fun, pulls harder in every gear
Old Nov 30, 2003 | 07:03 PM
InjectedSS's Avatar
NO 4.10 isn't the lowest you can get on a 10 bolt. They also have a 4.56 ratio but I can't imagine having that on anything other than a 6 speed, and having 33" tires.. Otherwise you'd definately be heading towards shifting into 5th. 4.10's are perfect for an M6 and 3.73's are perfect for auto's...
Old Nov 30, 2003 | 07:07 PM
InjectedSS's Avatar
your confused... His car has a HIGHER gear ratio than a 6speed car.. His car has 3.23's where an M6 come's with 3.42's... The higher the # the LOWER the gear ratio!
Old Nov 30, 2003 | 07:12 PM
tanker's Avatar
there are 4.56 for a stock ten bolt, haven't seen anybody having them though
Old Nov 30, 2003 | 07:28 PM
LT1 Bunny's Avatar
4.56s are worthless...if u like to burn tires and max out 120 in 6th....then they are fun! I know afew poeple that have had them and I know someone that has them on right now. But they are swapping them out for their 3.73s.
Old Nov 30, 2003 | 07:40 PM
ibanez6rg's Avatar
My buddy has/had 4.56s in his 6 speed.
Old Nov 30, 2003 | 07:53 PM
Cmr0z28's Avatar
really? thats funny, because you told me YOU had 4.56s in your 6 speed.
Old Nov 30, 2003 | 07:58 PM
ibanez6rg's Avatar
I don't have a 6 speed, chump.
Old Nov 30, 2003 | 08:34 PM
Cmr0z28's Avatar
you told me you did, chump. quit talking out of your ***!
Old Nov 30, 2003 | 08:41 PM
ibanez6rg's Avatar
I lie to you all the time, why would I tell you the truth? Keep this sh*t on AIM and quit getting off the subject, sucka
Old Nov 30, 2003 | 10:22 PM
Cmr0z28's Avatar
