3.73 vs 4.10 ratio mph difference
Old Dec 29, 2006 | 03:17 PM
leanjay's Avatar
could someone with 4.10 rear axle ratio and the m6 trans. please let me know what the engine rpm is at 80 mph. i have the 3.23 rear axle ratio right now,i run about 1800 rpm at 80 mph. i'm considering going to the 4.10 ratio soon. thanks alot!!!!!!!!!!!!!
Old Dec 29, 2006 | 03:22 PM
2001NBMZ28's Avatar
www.f-body.org/gears/
Edit: Sure you don't have 3.42's?
Old Dec 29, 2006 | 03:55 PM
69gto96z's Avatar
I think mine is a little over 2 grand, like 2200 or so but I never really go 80, unless I am racing...
Old Dec 31, 2006 | 02:56 PM
leanjay's Avatar
are you sure you don't have 3.42's
recently swapped from a4 over to m6, thats why i have the 3.23 ratio. thanks
Old Dec 31, 2006 | 03:17 PM
2001NBMZ28's Avatar
Reason I asked was because on a '97 M6 1800 RPM is 80 MPH in 6th. My car came with 2.73's, but put 3.42's in it a few years ago. Sometimes the door codes don't match what's in the car.
Old Dec 31, 2006 | 07:41 PM
Depends on the tire diameter. With a 3.23 rear, stock tire diameter (25.65" with the Z-rated tire option) you would be at 1,700rpm in 6th gear. You might want to check your tach vs. the PCM RPM reading, since the tach typically reads 100-200RPM higher than actual. The PCM will give you the true RPM.
When you go to other gear ratios:
3.42 - 1,800
3.73 - 1,965
4.10 - 2,160
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
