3.23 to 3.73 what do i need?
Old Jan 3, 2004 | 03:26 AM
speedracer93z28's Avatar
i need to know what parts i need for this, no tools because i dont wanna even mess around with the gears. i will be taking it to the dealership. so far i know i need the gearset along with a installation kit, is there anything else i need? and our rear end is the 7.5" 10 bolt right?
Old Jan 3, 2004 | 04:53 AM
ssbowtie1's Avatar
That should be all. The dealership should supply the fluid and posi additive. A few helpful things include making sure you get a kit that has axle bearings (might as well replace them). Also, welding the axle tubes isn't a bad idea and getting a rear girldle will also help. Good luck.
Old Jan 3, 2004 | 08:27 AM
Mike383LT1's Avatar
3.23 to 3.73
you are going to need someway to correct your speedometer slp sells what they call a black box or a custom burnt chip from ed wright or superchips
Old Jan 3, 2004 | 10:47 AM
ssbowtie1's Avatar
Unfortunately custom chips don't correct the speedo in 93 z28s. Also, I'm pretty sure SLP does not sell the conversion boxes anymore. Your best bet is to find one used or learn to live with an incorrect speedo which will also rack up the miles.
Old Jan 3, 2004 | 04:29 PM
i was just looking for some gears, and i need to know wheather i need the ones for a 3.08 and lower carrier, or the 3.23 and higher carrier.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
colts0455
Jul 24, 2015 04:51 PM
