2nd gen factory stall tq convertor
Old Mar 2, 2006 | 02:36 PM
phatts27's Avatar
does anyone know what the factory stall on a 73 z28 is? im planning on buying one for cheap, but need to know what its stall is. the guy is telling me that it is around 2200-2600. if this is what it is, than this is what i want. thanks.
Old Mar 2, 2006 | 02:50 PM
camaro81's Avatar
Re: 2nd gen factory stall tq convertor
The factory stall is pretty dang low, i think its around 1200. With my '81 I went to a 2000 stall and actually picked up .2 in the 1/8th, so I'd assume the stock one is pretty dang low.
Old Mar 4, 2006 | 06:34 AM
phatts27's Avatar
ok, thanks, but do you think the 80 converter would be the same stall as one from 73? this guy swears its around 2400 stall
Old Mar 4, 2006 | 08:41 AM
mike 96 ws6's Avatar
That stall speed would, of course, depend on the motor in front of it. But I doubt you would get 2400 RPMs from a stock converter without a trans brake and that would also likely include a big block up front, and maybe not then without breaking something.
Of course I'm just guessing based on some past F-body's I had. It may stall at 2400 with your motor but if it's a bone stock 80 converter from a v8 350 Camaro, that car only had 170hp@3800 and 270tq@2400. I'd guess with rated power outputs at those RPM's, a stall speed of more than 1800 would be detrimental and a 2400 RPM stall even worse.
73 camaro v8 350 specs =
245hp@5200 and 280tq@4000. My bet would be the 73 converter has a higher stall speed.
Old Mar 4, 2006 | 06:55 PM
phatts27's Avatar
thanks
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
