93 M6's faster?
Old Mar 3, 2006 | 06:55 PM
Jazsun's Avatar
93 M6's faster?
Ive heard that the 6 speeds in the 93 had better ratios which made them somewhat faster then other lt1 m6's. Any truth?
Old Mar 3, 2006 | 07:31 PM
n2ceptor's Avatar
Re: 93 M6's faster?
http://www.camarossworld.com/Specifications/
Automatic
Model
1st
2nd
3rd
4th
4L60
3.06
1.62
1.00
0.70
4L60-E
3.06
1.62
1.00
0.70
Borg-Warner T5 5-Speed Manual
Year
1st
2nd
3rd
4th
5th
All
2.95
1.94
1.34
1.00
0.74
Borg-Warner/Tremec T56 6-Speed Manual
Year
1st
2nd
3rd
4th
5th
6th
1993
3.36
2.07
1.35
1.00
0.80
0.62
(std)
1993
2.97
2.07
1.43
1.00
0.80
0.62
(G92)
1994+
2.66
1.78
1.30
1.00
0.74
0.50
Old Mar 3, 2006 | 07:55 PM
96HawkCnvt's Avatar
Re: 93 M6's faster?
I'm relatively certain that to get the M6 with the 3.36 ratio (I have one), you had to order it with 2.73 gears. After '93, you could only get 2.73 gears with an automatic.
I believe that the torque rating was also 400 ft/lb vs. 450 ft/lb for later M6 transmissions.
Todd
Old Mar 3, 2006 | 08:14 PM
6SpdLT1Z's Avatar
Re: 93 M6's faster?
M28 had 2.73's from the factory, M29 had 3.23's from the factory. 94+'s had 3.42s. M29 is the most deseriable of the 93's.
Old Mar 4, 2006 | 11:03 AM
Zcrazy5150's Avatar
Re: 93 M6's faster?
Todd
Thats not true you could get 3.23's in an auto too. 2.73's had the first gear lockout on the shifter but you could just cut it off and then be able to select first..
Old Mar 4, 2006 | 09:07 PM
rkinney's Avatar
Re: 93 M6's faster?
Yeah the 93's with the M29 with 3.23's were just a hair steeper overall than the 94+ with 3.42's. I have 93z with the M29 with 3.73's and it's just slightly steeper than a 94+ with 4.10's. Although in 6th gear on the higway I am at higher revs than the 94+ with 4.10's due to the 6th being a .62 versus a .50.
Old Mar 4, 2006 | 09:46 PM
Jazsun's Avatar
Re: 93 M6's faster?
Well I know my car has 3.23's w/ its A4 dont know if that means anything.
David Dempsey
Mar 12, 2016 12:42 AM
NewsBot
Sep 14, 2015 02:02 AM
CARiD
Sep 7, 2015 08:21 AM
browenb
Parts Wanted
Jul 20, 2015 07:34 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
