2nd to 3rd Gear Not Shifting At WOT?
Old Jan 25, 2007 | 07:06 PM
atch_rox's Avatar
I recently had my 4L60E transmission rebuilt about 6 months ago and lately I've noticed that the car will not shift into 3rd at WOT..... It will shift from 1st to 2nd wide open no problem but after that it just pegs the rev limiter until I lift off the throttle and then it shifts..... Any thoughts?
Old Jan 25, 2007 | 07:09 PM
12SCNDZ's Avatar
The 3-4 clutches aren't coming on fast enough. We've done a huge amount of work in this particular area of the 4L60E to prevent this from happening. You're battling with apply pressure, as well as holding power.
Frank
CPT
Old Jan 25, 2007 | 07:13 PM
atch_rox's Avatar
Thanks for the quick reply..... Anything I can do to fix the problem or will it need another rebuild?
Old Jan 25, 2007 | 07:43 PM
Performabuilt's Avatar
Supporting Vendor
Well there area few things you can do that might help but if it didn't start out that way at best you would be band aid it, Sounds like the 3-4 clutch has to much clearance now for whatever reason and as said its going. As stated above you do have to walk a tight line on the 3-4 clutch to get performance and durability and you wont get that with a stock rebuild or a stock build with a shift kit.
PCLZ28
Apr 29, 2015 11:56 PM
jb4xx
Feb 2, 2015 10:00 PM
Jul 4, 2005 05:00 PM
simple
Aug 2, 2002 03:30 PM
