2.73 to 3.73 questions
Old Aug 4, 2007 | 02:28 PM
reimer96z's Avatar
I'm swapping out my stock 2.73 for a strange engineering 3.73. Besides the ring and pinion I bought a deluxe install kit and rear end cover bolts. Is there any other parts i will need to complete the swap??
Old Aug 4, 2007 | 03:08 PM
You should have bought a gear set that would fit a 2 series carrier, since you did not say anything about swapping carriers.
Old Aug 4, 2007 | 10:41 PM
reimer96z's Avatar
ya i did buy a gear that will fit my carrier
Old Aug 5, 2007 | 12:26 AM
Need the right tools, including a dial indicator and a pinion depth checker, plus some indicator paste.
Old Aug 5, 2007 | 10:08 AM
reimer96z's Avatar
I was mostly wondering about the speedometer and ABS inop
Old Aug 5, 2007 | 11:25 AM
You have to reprogram the correct gear ratio into the PCM. The swap should have no affect at all on ABS, as long as you are using the same carrier you already have. You would only get a ABS INOP light if you damaged the sensor on top of the housing, or switched to a carrier that did not have the reluctor gear in the correct position. This assumes you have only ABS and not TCS.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
29
Mar 25, 2015 04:21 PM
blac94Z
Jan 5, 2015 06:13 PM
Jul 4, 2005 05:00 PM
