1996 t-56 which transmission fluid is recommended since.....
Old Sep 24, 2008 | 07:56 PM
djm_e22's Avatar
I have a 96 camaro and I read somewhere's that I am not suppose to use synthetic fluid pre-01(I think). Now is that pre-01 ls1 style t-56 or is that absolutely everything before 2001. I can't remember if I last used synthetic or not. If I did can I switch mine or do I now have to keep using it. Also if I do somehow remember that I did not use synthetic what do you guys recommend? Thanks.
Old Sep 24, 2008 | 08:19 PM
SnakeOiler's Avatar
never heard of that.
I use RedLine in mine.
Old Sep 25, 2008 | 10:51 AM
Z28SORR's Avatar
Only restriction on using syn. fluids is in the Auburn differentials. There is absolutely no reason not to use synthetic fluids in your car!!! Your T56 takes standard syn. ATF.
Old Sep 25, 2008 | 09:42 PM
JakeRobb's Avatar
Super Moderator
SixSpeedsInc (formerly T56Rebuilds) recommends either the GM-branded stuff or Mobil 1 ATF, both of which are synthetic.
Old Sep 26, 2008 | 01:02 AM
Green96Z's Avatar
Yes, you can use synthetic ATF. What you do not want to put in there is gear oil. It will destroy the blocker rings.
warmeck
Aug 24, 2024 08:05 PM
james007moore
Jan 1, 2016 01:14 PM
jmadoll
May 27, 2015 07:13 PM
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
