1995 4l60e valvebody
Old May 11, 2014 | 01:07 AM
antoine's Avatar
I have a question can be a 96 valve body work in a 95 4l60e because I have a car here with a transmission problem and I took it apart and found that it had 96 up valvebody
Old May 11, 2014 | 08:55 AM
12SCNDZ's Avatar
Re: 1995 4l60e valvebody
No. The 3-2 downshift valve is different between '95 and '96. The '95 uses a 2 piece valve that requires 2 holes in the seperator plate. The '96 uses a 1 piece valve with only 1 hole. No, they can't even be changed as a set because the different valve arrangement uses a different solenoid with different resistance.
You can, however, use a '94 (non PWM) valve body as long as you swap the TCC control valve line up and PWM solenoid out of the '95 valve body.
Frank
Old May 11, 2014 | 11:53 AM
antoine's Avatar
Frank
Thanks frank I know you would know
Old May 11, 2014 | 11:38 PM
antoine's Avatar
Also on this transmission the check valve behind the servo it's removed and a plug is there
Old May 12, 2014 | 01:04 PM
12SCNDZ's Avatar
That's perfectly acceptable as long as it's not leaking.
Frank
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
