1993 z28 gear change?? Speedo??
Re: 1993 z28 gear change?? Speedo??
Originally Posted by Aeromaks
Does the slp box work for a4's as well or no? the part numbers above are to go from 3.23 to 3.73? How hard would the install of either be?
Get the dakota box. 4 wires to run that's it. Pwr, ground, cut the VSS run one into the signal the other to the ouput 1 switch and your done. Adj the speedo is simple too.
Originally Posted by 93Phoenix
you cant flash the pcm for the new gears?
Jul 4, 2005 05:00 PM
teedoff59
Aug 8, 2002 01:36 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
