1993 z28 gear change?? Speedo??
Old Oct 13, 2004 | 03:42 AM
  #16
Fastbird93's Avatar
Re: 1993 z28 gear change?? Speedo??
Originally Posted by Aeromaks
Does the slp box work for a4's as well or no? the part numbers above are to go from 3.23 to 3.73? How hard would the install of either be?
The SLP box does work with the A4's. I've heard the install is somewhat confusing, as it's a lot of wire splicing. Couldn't tell you about the gear ring install though. Sorry.
Old Oct 13, 2004 | 08:12 AM
  #17
ZBLKHELLRZR's Avatar
Get the dakota box. 4 wires to run that's it. Pwr, ground, cut the VSS run one into the signal the other to the ouput 1 switch and your done. Adj the speedo is simple too.
Old Aug 28, 2006 | 07:26 PM
  #18
93Phoenix's Avatar
you cant flash the pcm for the new gears?
Old Aug 28, 2006 | 07:51 PM
  #19
Fastbird93's Avatar
Nope. Only in 94+ cars. The Dakota Digital SGI-5 works very well, and it's rather fresh in my memory as to how to wire it up so if you go that route and need some assistance, just let me know.
Jul 4, 2005 05:00 PM
CobraEatr
Jul 24, 2004 11:37 AM
teedoff59
Aug 8, 2002 01:36 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
