10 bolt
Old Feb 13, 2004 | 07:30 PM
1984camaroz28's Avatar
10 bolt
will et streets kill my 10 bolt. im making around 650hp. what can i do to build up my 10 bolt to handle this kinda hp. I dont wana spen 2grand plus on a 12 bolt
Old Feb 13, 2004 | 07:49 PM
chpmnsws6's Avatar
don't heat em up, don't stall it up, run it at half throttle
Old Feb 13, 2004 | 08:01 PM
there is a way to build up my 10 bolt
Old Feb 13, 2004 | 08:10 PM
Black6SpdTA's Avatar
For 650 hp? With ET Streets? I doubt it but here's the help I can give you:
-Support Cover (TA, MAC, etc)
-Weld the axle tubes to the housing
-If you're talking about your thirdgen, upgrade to 28 spline axles
-Super Duty posi unit (Zexel HD, Eaton, etc)
-Run a gear lower than 4.10's, they seem to be more stressful on 10-bolts
AFAIK, these are all the performance mods to a 10-bolt. Good luck.
Old Feb 14, 2004 | 12:28 AM
i saw in one mag a impala with 800 hp supercharged on a 10 bolt but it had a 800pound eaton posi unit where do i get one
Old Feb 14, 2004 | 08:11 AM
Summit sells Eaton stuff. Don't know about that heavy duty stuff though.
www.SummitRacing.com
Old Feb 14, 2004 | 10:47 PM
chpmnsws6's Avatar
it is also an 8.5 inch 10 bolt. you have a 7.5 inch 10 bolt
the 8.5's can handle alot more than these can
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
