0-60
Re: 0-60
Depends which T56 trans your 93 has. Is it an M28 or an M29? Affects the selection of the rear axle ratio, because of the difference in 1st gear ratios. And the 93 T56's are different than the 94-02 versions, with different gear ratios.
4_3
As you can see, the M28 and M29 have different rear axle ratios as well.
4_3
Re: 0-60
The RPO codes (M28 or M29), are listed on the service parts label, in the glove box, the console, or on the end of the driver side door. You will also find the rear axle ratio codes, GU2 for 2.73:1 gears, or GU5 for 3.23:1.
There is also a website where you can enter the VIN and get a complete list of RPO codes, paint and interior codes, and the build date for your car. There is a small fee.
Re: 0-60
0-60 times are hard to predict and even harder to make consistent without a plethora of electronic aids. If you look at any manual car that does a sub 4 second 0-60 you will see that they all do it in 1st gear so there is no shifting involved to slow them down.
Re: 0-60
Logically, you want the car to cross the 1/4-mile finish line in 4th gear, near max RPM..... unless you are strictly a stoplight racer.
You haven't mentioned your car's weight, RPM redline, or HP. All of those are going to affect the performance. And, do you have tires that provide the traction you will need to optimize 0-60MPH performance?
NewsBot
Sep 14, 2015 02:02 AM
Aug 7, 2015 01:26 PM
number77
Oct 29, 2003 08:09 PM
