will 16x9.5 et streets fit under fenders?
Old Aug 23, 2002 | 10:44 PM
roofo's Avatar
Question will 16x9.5 et streets fit under fenders?
I was thinking of getting a set of et streets or dragslicks.I wanted to put them on my stock rims.Will the 16x9.5 fit inside the fenders?My car has the sportline springs that is why I ask.The tires have to fit inside the fenders.I don't want to rub at all.Thanks Jeff
94 white Z28,looks good,runs good,sounds good!
Old Aug 24, 2002 | 09:50 PM
Wicked's Avatar
Post
I've run them and know a few people that have run both sizes(11.5s and 10.5s) of ET Streets on a 16" rims and have had no problems.
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
Old Aug 25, 2002 | 07:16 PM
speedmiser's Avatar
Post
I second that. I ran 16 x 11.5's ET Streets on a set of Salad shooters for about a year with no problem.
Old Aug 26, 2002 | 01:03 AM
Joe Brodman's Avatar
GP Moderator
Exclamation
I run 26x11.5x16 ET Streets on 16x9.5 Centerlines, no rubbing whatsoever.
94 Firebird Formula Ram-Air, M6, T-tops, N2O, 12-Bolt, Bolt-Ons; was running 11's internally stock.432.8 RWHP / 588.4 RWTQ
No new times or dyno numbers with new top end (CC306, 1.6RR's, ported heads, etc.)
Old Aug 26, 2002 | 02:00 AM
rskrause's Avatar
Moderator
Post
Not sure about the Sportlines. But with Eibach Pros 16x11.5 ET Street fit on salad shooters. The Sportlines drop the car even further, right? I did remove a portion of the inner fender lip at the bottom rear corner. There wasn't much clearance and I was worried about tire expansion causing interference.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
