Wheel hop bad
Old Aug 4, 2003 | 12:14 PM
sleeperz28's Avatar
Wheel hop bad
I never had any problems with wheel hop until this year. I got rid of my single turbo and put twins on the car. There is a little more weight in the front of the car which lowered it a little. I also put 315's in the rear of the car 17" rims, last year I had 245's on 16" rims. Last year the car would either spin a little then hook or grab and go. This year the car wheel hops so bad I have to let off the gas. Im wondering if its the 315's because I have to run about 30psi in the tires where I had 17psi in the 16" rims allowing the tires to wrinkle.
What do you guys think?
Old Aug 4, 2003 | 01:17 PM
Dragon Racing's Avatar
Aftermarket lca's and relocation brackets should help to clear up your wheel hop.
Old Aug 4, 2003 | 02:25 PM
TedH's Avatar
Check the rear sway bar bushings and end links too. Easy to change and often a culprit.
Old Aug 4, 2003 | 10:22 PM
96LT14u2Nv's Avatar
yeah, any cheapy LCA's (lakewood sell for $87) should help that out TREMENDOUSLY
Old Aug 9, 2003 | 01:59 PM
Geezer powered's Avatar
do you have subframe connectors??Your car could be twisting.
Old Aug 9, 2003 | 04:28 PM
sleeperz28's Avatar
Reset my pinion angle that seem to take care of everything.
Old Aug 9, 2003 | 06:02 PM
what times and hp you running with that thing
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dale3in98
Feb 14, 2015 12:18 PM
Jason Short
Jan 19, 2015 06:33 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
wytblur
Aug 5, 2002 02:03 PM
