What's your best R/T?
Old Jul 19, 2002 | 08:48 PM
  #16
Mezmorized's Avatar
Post
I've been drag racing since 1987, in all that time I've had alot of great lights, I've also had about 3 .500 REDs Turns out the computer rounds off the numbers like .49999 becomes .500 but red.
Can't cut it much closer
"Yea, though I walk through the valley of rice,
I shall fear no turbo, for torque art with me."
86 Z28 LG4 AUTO
79 Malibu 357 1/4:11.56@116mph
http://www.highperformancecars.com/poisonivory
Third Watch Squadron
Old Jul 20, 2002 | 04:52 AM
  #17
Speeds8erM-1's Avatar
Post
My best is a .000.
Old Jul 20, 2002 | 05:42 AM
  #18
Aneurysm's Avatar
Talking
My best R/T is a 0.562.
Now what makes this so special is I pulled this on my third drag race I ever did. (today). My buddy said hes been racing for 3 years and his best was a bit over 0.6, AND I drive a Manual, so I seem blessed with reaction.
2001 Camaro SS #C095
Light Pewter Metallic
M6, T-Tops, Ebony Leather
All Options
Words of Wisdom
[This message has been edited by Aneurysm (edited July 20, 2002).]
Old Jul 20, 2002 | 11:11 PM
  #19
Smokn '94 Z's Avatar
Smile
.500 I could usually stay in the .5 to .6 range.......
Teal '94 Z Beefed up A4, , 3.73 Motive & Eaton Posi. -----------Best ET. 13.61 100.7 mph 1.86 60' on BFG Comp Ta's 17" Now I Just installed Hot Cam Kit, FLP's, A.I.R., EGR, TB Bypass, TPI's Aluminum Driveshaft, 52mm TB, Corsa, DMS springs, & PCM for less.
Old Jul 21, 2002 | 12:17 AM
  #20
rje's Avatar
rje
Post
.501 on a full tree and .546 on a 5 tenths pro tree.
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.55 60ft 7.16 @ 96.04 mph 11.27 @ 118.41 mph (125 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
silvermansteve
Mar 4, 2015 05:02 PM
rncotton
Oct 18, 2002 07:41 AM
Notford95
Aug 20, 2002 01:46 AM
96z
Aug 2, 2002 09:00 PM
Aneurysm
Jul 22, 2002 08:42 PM
