What tire pressure should I be running?
Old Aug 28, 2006 | 04:09 PM
94zrag's Avatar
I'm using a set of m/t et streets(not the radials), and I was wondering who's had luck with these, and what psi do you run them on? So far I've only been able to cut 1.9 60's, but I know with some practice i'll be able to bring that down.
Old Aug 28, 2006 | 11:47 PM
AL SS590 M6's Avatar
Moderator
Re: What tire pressure should I be running?
15-16 hot
Old Aug 29, 2006 | 09:51 AM
TedH's Avatar
Try 14.5 cold. Everybody has opinions, but I do not check tire pressure when they are hot. I time my burnouts to be as close to the same each time and actually I run between 13.5 and 14 in mine, but everyone's suspension if different. Use the same tire gauge each time so if it is off a little bit it won't matter as the difference between readouts will always be the same.
Old Aug 29, 2006 | 04:29 PM
The Engineer's Avatar
I check my slick pressure (ET Streets 26" x 11.5) just before each run while in the staging lanes. On a very hot day, between rounds pressure can easily climb 2 PSI, or drop on cold days. Also, you can have the issue of one slick in the hot sun and the other in the shade, which can cause several PSI difference between sides.
With my ET Streets, I typically run between 14.5 and 13.5 PSI depending on the track conditions. After the first 100 feet or so, low pressure is rolling resistance and possible control problems on the top end.
Old Aug 29, 2006 | 07:10 PM
94zrag's Avatar
I appreciate the responses guys. I only ran 14psi once, and the car was swaying pretty good on the top end and after each shift, and I wasn't sure if that was normal, so I upped the pressure. Guess I'll drop it back down some and try again.
Old Aug 29, 2006 | 07:22 PM
94zrag's Avatar
Hey, while i'm in here. What kind of a burnout do these tires like?
Old Aug 29, 2006 | 07:48 PM
The burn-out should clean them off and get them hot and they will hold if the track prep is good. Do the same burn-out each time. I have a line-lock on the front brakes which allows me to really heat-up the slicks then I release the line-lock continuing the burn-out, then let off. Don't dry-hop on the way to staging.
http://www.cardomain.com/ride/2189634
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Ken Cemo
Jan 27, 2015 08:45 AM
Jason Short
Jan 19, 2015 06:33 PM
